09-23-2005 02:53 PM
The last sequence looks more complicated than it is. The time boxes (input and output) are formated as relative time (right-click and choose "Format and Precision"). This means they are relative time from the beginning of the day (midnight), but they actually keep that data in seconds from the beginninf of the day (midnight). For example 01:00 (1AM) becomes 3600 (60 min*60sec/min).
@robin171 wrote:Thank you very very much!! I really appreciate your help!Can you explain how the code in the last flat sequence works? I understand that you substract the system time from the time set in the array. How does it exactly work ?<SNIP>
09-23-2005 03:31 PM
09-23-2005 04:29 PM - edited 09-23-2005 04:29 PM
Thank you! I rated your posts!
I almost got the complete program working now 🙂 There are a few things that don't work perfectly, but i'll try to figure them out myself first. I'll let you know if i encounter any problems again!
Again .. thank you very very much! Labview is new to me and i must get used to this type of programming. With Delphi or C I can easily make this kind of programs, but Labview is hard for me.... I guess i have to practice a lot to become as good as you 😉
Message Edited by robin171 on 09-23-2005 04:50 PM
09-25-2005 02:57 PM
09-26-2005 06:31 AM
09-26-2005 11:37 AM
After i save some starttimes/days, I press the stopbutton to put the starttimes/days in the array. The program should stop when i do so, but it keeps running.
And i have another problem with my temperature control. I placed an simulate signal block to simulate the input of a temperature, just for testing. It doesn't run at all 😞
09-26-2005 01:15 PM - edited 09-26-2005 01:15 PM
Message Edited by Robert.Bedford on 09-26-2005 01:16 PM
09-26-2005 04:41 PM - edited 09-26-2005 04:41 PM
thanks for your help again!
I still got the problem. The stop just keeps pressed and nothing happens. I had the program run for about 25 minutes. After pressing the stop button i can't press anything in the VI. Only the abort execution button can stop the program.
I included an screenshot with this post to make it more clear. Am I doing something wrong, or is it my labview? I got version 7.1 prof edition.
Message Edited by robin171 on 09-26-2005 04:46 PM
09-26-2005 05:12 PM
09-28-2005 03:18 PM
