07-07-2005 02:38 AM
07-07-2005 04:00 AM
Hi Claudia
Now again - as Novatron mentioned you have to change the loop condition. Now you have it "continue while true" which is why it is stopped immediately - the stop button is false. Change it to "stop if true" as you can see on the picture. Just right click on the condition and change it.
And then it should work - on my pc it worked after this modification.
Hope this helps.
Thomas
07-07-2005 04:20 AM
I know, but this options aren't there by me. Is it possible, that Labview 5.1 doesn't have this opportunity?
Or do you know why I can't see it?????
07-07-2005 04:26 AM
07-07-2005 04:45 AM
Do you mean it this way?
this way it only change between 0 and 1 again.
07-07-2005 04:49 AM - edited 07-07-2005 04:49 AM
Message Edited by becktho on 07-07-2005 11:50 AM
07-07-2005 06:19 AM
It works!!!!!!!!! Thank you so much!!!!!!
Is there a opportunity to count all the events in an other counter and when you open the next time this programm somewhere this counter carry on with the last value.
07-07-2005 07:08 AM
You can use this vi as a sub-vi an pass the last value of the counter (just wire an indicator to the right shift register). The initial value of the left shift register should be replace with a control. So you can start the counter with another value.
07-07-2005 01:45 PM
07-19-2005 02:25 AM
Hi again!
Is there any change to do the "stop" out of the loop?
Thank you!
