04-09-2015 08:09 AM
Hi All
Is it possible to count input pulses without a counter function?
I am using a Mydaq which only has one counter and it only counts up
If I can count without a counter function, I can achieve all I need to achieve.
I would need to be able to count up and down do
Please advise if this is possible and if so, how.....
Regards
Greg
04-09-2015 09:19 AM
Got it Sorted...
08-06-2018 03:51 PM
How? Can you please explain or help.
08-07-2018 10:08 AM - edited 08-07-2018 10:09 AM
I assume he found myDAQ's counter an count in both directions. Here is some more information about it: How Do I Use the NI myDAQ Counter?
Does this answer your question?
08-07-2018 10:11 AM
Thank you for the reply but my query was if i can use other digital inputs as counters... As my daq has only one counter and i need to count pulses for 5 different inputs...
I am looking for solution in LabVIEW...
08-08-2018 01:43 AM
08-08-2018 01:49 AM
Hi GerdW
Thank you,
Solved it using Boolean PtbyPt block.😊
Regards
Rishav Preet
