05-23-2016 10:12 AM
You are right, it's counting how many spaces it receives in a second, not the actual number of incoming strings... Is there a way I can just sense that a string is received and trigger something like a boolean, and just count how many times that boolean turns TRUE or something?
SM
05-23-2016 12:25 PM - edited 05-23-2016 12:27 PM
Sure, try to describe that trigger or boolean and find it. An example of typical messages would help but like I said a return followed by a space may work. Or you can get more fancy and try to find it using regular expressions, which I have less experience with but know is possible. Also instead of the simple search replace, you could have a while loop, that finds the search with more work but will be more flexible. Either can do something like "Find a string that starts with a space followed by a string".
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
05-25-2016 08:26 AM
I was trying to use a While loop to pulse a boolean light when it receives a string of any character, and just count how many times a second that light is pulsed. But I couldn't get it to work. Do you have an idea or an example on how to do this?
SM
