10-27-2006 10:05 AM
Dear,
I am doing an experiment about baroreflex (Blood pressure reflex) using a system of PowerLab (ADInstruments). I have many data that I want to do Spectral analysis and try to find specific software to do that. I found from literature that you may have a software (LabView?) could do spectral analysis of blood pressure. If so, could I do the spectral analysis only use your software?
Thank you,
10-30-2006 03:00 PM
Hello mlin,
LabVIEW can interface with your transducers using hardware. Once the acquisition is over, LabVIEW can get the data and convert the time information into the frequency domain so that you can see the amplitude of each of the frequencies involved with the signal. I am just curious about the equipment you will be using. You will need some data acquisition cards that have drivers for LabVIEW unless you are just getting the information from a desktop instrument. If you are using a desktop instrument, then LabVIEW could send the commands to automate the process. I hope this answers your question.
Steven T.
