11-30-2012 05:29 AM
Hi
I've got a VI set up where I'm transferring various attributes from one control to several others, using property nodes. Since the list of attributes is getting quite long, I wondered, is it possible to do the same thing using a reference or some other method instead? (I'm using LV7.1).
Appreciate any advice,
Bruce
11-30-2012 06:34 AM
Is there a reason why you're trying to do this?
11-30-2012 08:57 AM
Try something like this.
12-04-2012 03:49 AM
Hi Bjorn
The VI is part of a prompt to allow details to be entered from upto 7 different units under test. For each unit, I have various controls for inputting information, on individual tab pages to separate everything out. Since the hardware in the units can vary, I wanted a way of modifying all relevant controls to highlight the fact that there are differences. At the moment, I use several master controls and transfer the attributes from those, but I just thought there must be a better, more efficient way of doing this.
Kind regards
Bruce
12-04-2012 03:54 AM
Hi pcardinale
Thanks for that. You couldn't send it again in LV 7.1? Unfortunately, I've not got Labview 9.
Kind regards
Bruce
12-04-2012 08:49 AM
I can only go back to LV 8.0
12-06-2012 05:19 AM
Hi pcardinale
I got the file converted to 7.1. Thanks alot, that's just what I was after.
Bruce
