Copying cRio modules channel names in project
I am trying to see if there is a way to make a duplicate of a cRio chassis in a project. I can Ctrl+C and Ctrl+V to copy/paste the entire RT Compact Target but the names I gave to each channel in each module does not get copied over.
Attached is an example of what I am running into. The first chassis has names labeled to each channel and when I copy/paste, the channels in the modules are relabeled to the defaults.
Reason why I am curious is because my project will consist of 4+ Rios with many modules with specific channel names. I don’t want to risk mistyping a name.
I am using LabView 13
Thanks for the help,
Eugene
(2,501 Views)
Accepted by topic author eyang
To exactly duplicate the same target do this:
Click the RIO Target you want to duplicate press Ctrl and Drag the RIO target, you can see a duplicate target is created with all the channel names similar. If you feel you are not able to drag it below then drag it above the target. Smiley Wink
(2,464 Views)
