I can do this! Problem is that I want the user to see only "Before" but copy to clipboard "After".
Imagine situation: someone is working with our application. He sees gray graph that isn't very printer-friendly. He wants to add the graph to his Word (Excel,... ) document and then print it. It means to make the graph printer-friendly looking.
There are two ways. User pushes button (or shortcut menu...)and program customizes the graph and saves the customized graph as PNG (or BMP... )and then user can import picture to Word. This is done in "save.zip" - run "before" and press "Save to picture". But this is not very comfortable for the user. He must save it and then import it from file to Word... it takes a lot of time.
Much effective would be to copy customized graph directly to clipboard and then he can with "ctrl+v" import it to Word. It is much faster!
Do you understand the idea now? User wants to copy "more white" graph to clipboard and then....whatever he wants
jochynator
LV 8.0.1, WinXP Pro
