02-04-2009 05:35 PM
Would anyone be able to convert the attached driver library from version 4.1 to a version that could be read by version 8.5 or 8.6? This is for a laser diode controller, and is the only version offered for download by the manufacturer (ILX Lightwave).
Thanks in advance for any help you can provide.
Richard
02-04-2009 06:27 PM
02-04-2009 07:24 PM
Thanks!
I was able to open the vi's in v8.6. Now I get to spend a little time to see if they actually work ...
Richard
03-30-2010 11:25 AM
Would you be able to convert the driver library from version 4.1 to a 6 version, as you did for the 8 previously? This is for the laser diode controller LDC-3724B, and is the only version offered for download by the manufacturer (ILX Lightwave).
Antony
03-30-2010 02:17 PM
