08-29-2013 12:58 PM
I am beginning the transition from LabVIEW 2010 to 2013 and thought all was going well until I looked at the Run-Time window. It should have a custom menu and no scroll bars (which it does) but it also still shows inactive scrool bars and the original menu from the working front panel. WhaT am I doing wrong?
08-29-2013 07:38 PM
Try disabling AERO in windows, or selecting a different theme.
08-30-2013 08:42 AM
The computer is a Windows 8, Lenova Ultrabook. Changing the Windows theme WHILE the VI is running does sometimes make the problem disappear, but it comes back as soon as I stop and restart the VI. Turning off unnecessary animations and removing background images (the closest I can find to disabling AERO in Windows 😎 has no effect on this problem.
08-30-2013 02:04 PM
Is there a diff between using Clasic controls and Modern? You might try installing Classic Shell (third party Windows 8 for adding legacy features). YMMV.
