07-10-2015 10:28 AM
I'm using the ColorImageToArray.vi to take an image and convert it to an array. Since the image is actually grayscale, I'm using array subset to take one plane from the array. I want to convert this array to uint8 for some processing in a MATLAB script node. When I try to do this conversion in the script node convertedarray = uint8(array) it gives me an empty array.
When I try to use the To Unsigned Byte Integer function in LabVIEW, it gives correct values, but MATLAB still sees it as an array of doubles.
How can I cast a 2D array to something that MATLAB sees as uint8?
07-11-2015 01:19 AM
It seems to me that your problem is with matlab. Maybe you should ask in their forum.
Can you show is some code?
