Converting String Array to Integer string
I need that to be sure all elements are processed in the worst case.
Message 11 of 22
(1,867 Views)
You should use a while loop and stop when you run out of elements. You still have not explained the algorithm.
Message 12 of 22
(1,865 Views)
Here's all you need to read the two files:
Message 13 of 22
(1,859 Views)
Two text files are the time of rising edge two separated ones and I want to detect the latency between signal1 and signal2 (Ther are already sorted). So I transfer them into two arrays and check the first element of them. If the signal2 element is greater than signal1, it should be removed from signal2, if they are equal, both should be removed in case of the greater, signal1 should be removed and so on.
Message 14 of 22
(1,856 Views)
You do that for the first element.
Once that is done, do you care about later elements in the arrays?
Message 15 of 22
(1,853 Views)
Do you need the leftover pieces once things are removed or do you just need it for the processing?
Message 16 of 22
(1,850 Views)
You have not explained the middle shift register where you buld an array.
It would be much easier to explain it with an example.
Message 17 of 22
(1,846 Views)
I do not need them
Message 18 of 22
(1,846 Views)
@Mmehrabin wrote:
I do not need them
OK, no need to chop up the array. Just keep track of the current index.
Does the code currently work as desired? What result would you expect for array5 given the example files.
Message 19 of 22
(1,843 Views)
It works now. Thank you
Message 20 of 22
(1,831 Views)
