If it is NOT in big endian order, then you can use Join Numbers (Advanced - Data Manipulation palette) to join the bytes in the correct order. First join the two MSBytes(U8) together to form U16 upper, then the two LSBytes(U8) together to form U16 lower, then use join numbers to join the two U16s to form a U32.
