Hi Navaeen,
In your first case, there's a space in your ".4176 4768" and in the second case there's a space in "d b". That could've been caused by copy-and-paste from your labview code though.
The main problem should be the syntax of the "^" operator. Starting from LabVIEW 6.1, "^" represents the bitwise exclusive or (XOR). Use "**" for exponentiation.
And also you have a right parenthesis missing in your second case.
Dan
