07-01-2013 08:59 AM
Thanks Altenbach. I did realize that my code is not scaleable, and the 'ABC' was a carryover from an example that I had started from. The output from the sensor that I'm reading will always have 2 characters, therefore scalability was not a concern.
Regarding your example, how are you converting the characters to binary? Does that take place via the 'String to Byte Array'?
07-01-2013 04:26 PM
jdeters79 wrote:Regarding your example, how are you converting the characters to binary? Does that take place via the 'String to Byte Array'?
All I did was making a lookup table, then indexing into it. Every possible result is precomputed using standard LabVIEW tools, then turning the result into a string array diagram constant.
