Convert an U8 array to a LabView data type
@Scott-D wrote:
It works!!!  thank you guys so much! I use Unflatten from string with "native, jost order" to solve the byte swap problem.
I would recommend to use "little endian" instead. The byte order does not depend on the host system, but on the source that generated the data. If you use native host order, it will not work correctly e.g. under linux.
Message 11 of 11
(1,143 Views)
