02-09-2012 05:24 AM
What if I don't want to setup M.S Office to my computer? I don't use M.S. office and I didn't setup M.S Office on my workstation but I still want to convert this files TDMS to EXCEL. Do I have to setup M.S. office if I use this conversion?
02-09-2012 09:23 AM
The VI you refer to directy uses MS Excel through its COM interface, and within MS Excel the NI TDM Excel Add-In to read TDMS files. So if you do not want to setup MS Office on you computer, you will have find another solution that does not require MS Office.
02-09-2012 11:18 AM
Hi No_RegreTs,
The trouble is creating the Microsoft binary *.xls or *.xlsx file, which LabVIEW doesn't do natively. If you don't want to rely on Microsoft Excel to write the resulting Excel file, would it be sufficient to create a tab-delimited ASCII file that loads into Excel? Many customer do this and then name the tab-delimited ASCII file with a *.xls file extension so that double-clicking on it loads the file into Excel automatically (albeit slower than a "real" *.xls" file). LabVIEW does have a "Write To SpreadSheet File.vi" that would create a tab-delimited ASCII file.
Brad Turpin
DIAdem Product Support Engineer
02-17-2012 01:21 AM
Thank you very much.. I'll try to do it using spreadsheet subvi.
02-21-2012 04:09 PM
Not that I've ever used it, but there is a TDMS addin for OpenOffice as well.
http://zone.ni.com/devzone/cda/tut/p/id/6849
No idea how difficult it would be to perform the same operations with OpenOffice.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
