03-25-2015 10:43 AM
Hello & thanks for reading! I have searched forums and tried to solve this myself. I have a USB spectum analyzer from Tektronix which outputs it's data in I/Q form. I need to see the data as you would on a standard spectrum analyzer display. When ever I download an example it seems toolkits and .vis are called for which I don't have. I am using LabView 2014 full development version only. I have an example python program, but am having trouble translating to the proper LV .vis. I'll attach the example program. I know I should know this, but its been years since I dealt with complex numbers etc.
Help will be greatly appreciated.
Sincerely,
Stan
03-25-2015 11:25 AM
03-25-2015 11:47 AM
Thanks for the reply. Sadly, this model doesn't support SCPI type fetch commands, and LV can't see it with VISA. I have an open ticket(7436871) on the latter, but never got a resolution. I have had to rely on imported .dll files, which seem to work.
03-25-2015 12:04 PM
03-25-2015 01:23 PM
RSA 306. (Sorry)
03-31-2015 01:40 PM
BUMP!
Still looking for an answer.........
Thanks!
04-01-2015 10:21 AM
I'm not entirely clear on which functionality you're having trouble replicating in LabVIEW, but you mentioned complex numbers; if you right-click on your block diagram to access the functions palette, and go to Numeric->Complex, you'll find a number of VIs that are built for working with complex numbers.
Here is a link to the help pages for these functions:
Complex Functions
http://zone.ni.com/reference/en-XX/help/371361L-01/glang/complex_functions/
12-17-2015 08:24 AM
I know this is a fairly old topic, but I'm looking for a solution too. I did come across the following on the TEK site, but it doesn't satisfy me.
http://www1.tek.com/forum/viewtopic.php?f=8&t=6564
Basically, it says you can use a different model LABVIEW driver as long as you run the SignalVU-PC behind LabVIEW (and install the VISA drivers in a specific order). I don't want to require the SignalVU software to be running just to work with the device. I've seen some other threads that dead-end with the comment that the SignalVU software handles GPIB emulation.
Has anyone figured out how to interface with the RSA306 without running SignalVu in the background?
12-17-2015 03:56 PM
If you have a spectrum in complex I,Q values vs frequency, to convert to power get the amplitude (=(I^2+q^2)^0.5) (or use re,im to amplitude and phase function in LV and just take the amplitude), then square it. This gives a measure of power vs frequency- you may need to multiply by a constant but that depends on your units and scaling.
12-17-2015 04:45 PM
I believe the function you are looking for is FFT Power Spectrum and PSD:
