Convert Hexadecimal String to Byte Array
Accepted by topic author Nelval
Hi Neival,
something like this may work for you:
(String in normal display mode…)
Message 11 of 29
(5,438 Views)
I already came up with a solution pretty similar, I was expecting something a bit more builtin from LabVIEW, anyway, thanks.
Message 12 of 29
(5,426 Views)
Sorry for the misunderstanding... another way of doing the conversion
Message 13 of 29
(5,419 Views)
And where do these "solutions" do a left padding of the last "4" in the original example string?
Message 14 of 29
(5,415 Views)
Hi Christian,
why insist on left padding? Conversion of trailing "4" will give the expected result 4…
The question should rather be: Why does the data source omit the zero padding leaving us with an odd number of chars?
Message 15 of 29
(5,412 Views)
Yes, yours does, but the other two don't.
Message 16 of 29
(5,407 Views)
Here's what should cover all scenarios (odd or even lenght)
Message 17 of 29
(5,401 Views)
Thanks for completing that part of the solution.
Message 18 of 29
(5,388 Views)
I know this post has been marked answered, but I just can't help myself.  And I do have the greatest respect for Chris' experience.
Mostly in answer to Vijay's several attempts (some flat-out wrong, and the final one close but improvable), I'll attach the following two images (note, only one is a snippet):
Apologies to all and best regards,
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
Message 19 of 29
(5,347 Views)
for the fun of it:
Message 20 of 29
(5,331 Views)
