01-17-2013 11:43 PM
How can we convert a program written in labview 6.1 to program readable in labview 11?
Solved! Go to Solution.
01-17-2013 11:55 PM
You can ask for a conversion in the Version conversion Board along with the file.
01-18-2013 12:03 AM
I think you dont need a conversion. Higher version will automitically read the older version.
01-18-2013 12:06 AM
No. It is upto some versions only if that is below then you need an upconversio to read them in higher versions
01-18-2013 12:47 AM
thanks a lot for ur help . .keep in touch
01-18-2013 06:53 AM
LV2011 can open VIs from all the way back to 6.0. See here for the complete rundown: http://www.ni.com/white-paper/8387/en
