06-28-2016 11:18 PM
06-28-2016 11:41 PM - edited 06-28-2016 11:42 PM
SGL is correct. However you need to remember that LabVIEW is big endian, so you might need to convert from/to little endian when communicating with external programs or writing to binary files, etc.. What are you planning to do with it?
Please give an example of what you are trying to convert, what you expect to get, and what you are getting instead.
06-29-2016 12:38 AM
06-29-2016 01:19 AM - edited 06-29-2016 01:20 AM
Hi Rao,
a perfect moment to tell strongly advice you to attach VIs or snippets when you have problems with your LabVIEW VIs!
From your writing I guess you use the function "To SGL", which will convert the value from U32 datatype to SGL datatype.
You need to use Typecast to reinterprete the memory content of the U32 as SGL…
06-29-2016 01:31 AM - edited 06-29-2016 01:32 AM
@RaoSudeshna wrote:
I'm trying to convert U32 number to float....
For example I need to convert 1903 to float...I expect to get it as 2.66667098e-042
But I'm getting the same value 1903 using SGL
I beleive there is a confusion here. The OP mixes the number format with data type. The data type is one thing, the format is another. To change the number format of a numeric indicator, right click on it, go to "Display format", and chose "Scientific":
06-29-2016 02:42 AM - edited 06-29-2016 02:43 AM
The main problem was that you used the term "conversion", which is typically not used for type casting operations.
Apparently, your problem is solved, bu here's an old summary on the differences between conversion and casting (and flattening/unflattening).
06-29-2016 03:00 AM
Ok, so not the OP but me who was confused 🙂
