08-05-2013 10:02 AM
I am trying to import Vector Cantech BLF logging files into LabView. Does anyone know of a converter or process to do such a thing?
Thanks!
08-06-2013 11:35 AM
Good day!
National Instruments offer a series of Data Plugins to extend the data file acces capabilities of NI products such as LabVIEW, DIAdem and NI Data Finder. Among these dataplugins, there are two for Vector products.
Check the following links to learn how to use Data Plugins with LabVIEW:
http://www.ni.com/white-paper/11951/en
And the following two to download the relevant Data Plugin (I don't know which version of the MDF file you are using)
http://zone.ni.com/devzone/cda/epd/p/id/452
http://zone.ni.com/devzone/cda/epd/p/id/6568
Hope that helps!
Cheers.
08-26-2013 04:12 AM
Hi all,
Is there is any data Plugin for Vector BLF files.
MDF plugins only supporting Vector Logfiles but, I need to read BLF files with Labview.
Please tell me if there is any data plugin can read the .BLF files.
BR,
Guru
08-26-2013 05:09 PM
The Vector BLF Format is supported in DIAdem through the CAN Log Converter. I would direct any questions related to that to the DIAdem Forum.
Vector BLF format is not supported in LabVIEW beyond the resources Luis linked above.
08-26-2013 07:41 PM
Dear Joey S,
Thank you so much for your reply.
I tried with DIAdem buslog converter, it is working fine.
But, I want to read with Labview environment because I need to create .exe (Installer) after creating VI.
BR,
Guru
08-27-2013 03:23 AM
Dear all.
I also encountered this issue during my coding, need .blf data file be recognised in Labview environment and can be unpacked accoring to .dbc file (Vector file). i have tried with .mdf format, i can open and read data inside, but i don't know how to convert .mdf by .dbc file, since this .mdf file is logged with .dbc configuration.
Joey,
can you help this effrot, appreciate.
Haitao ,china
02-27-2017 10:59 AM
