Nanie, I've used these example extensively and I think I can help. Incidently, there is actually a bug in the examples, but I will start a new thread to discuss this (I haven't written the post yet, but it will be under "Bug in Graph Acquired Binary Data.vi:create header.vi Example" when I do get around to posting it). Anyway, to address your questions about the scaling. I've included an image of the block diagram of Convert Unscaled to Scaled.vi for reference.
To start, the PCI-6220 has a 16bit resolution. That means that the range (±10V for example) is broken down into 2^16 (65536) steps, or steps of ~0.3mV (20V/65536) in this example. When the data is acquired, it is read as the number of steps (an integer) and that is how you are saving it. In general it takes less space to store integers than real numbers. In this case you are storing the results in I16's (2 bytes/value) instead of SGL's or DBL's (4 or 8 bytes/value respectively).
To convert the integer to a scaled value (either volts, or some other engineering unit) you need to scale it. In the situation where you have a linear transfer function (scaled = offset + multiplier * unscaled) which is a 1st order polynomial it's pretty straight forward. The Convert Unscaled to Scaled.vi handles the more general case of scaling by an nth order polynomial (a0*x^0+a1*x^1+a2*x^2+...+an*x^n). A linear transfer function has two coefficients: a0 is the offset, and a1 is the multiplier, the rest of the a's are zero.
When you use the Cont Acq&Graph Voltage-To File(Binary).vi to save your data, a header is created which contains the scaling coefficients stored in an array. When you read the file with Graph Acquired Binary Data.vi those scaling coefficients are read in and converted to a two dimensional array called Header Information that looks like this:
ch0 sample rate, ch0 a0, ch0 a1, ch0 a2,..., ch0 an
ch1 sample rate, ch1 a0, ch1 a1, ch1 a2,..., ch1 an
ch2 sample rate, ch2 a0, ch2 a1, ch2 a2,..., ch2 an
The array then gets transposed before continuing.
This transposed array, and the unscaled data are passed into Convert Unscaled to Scaled.vi. I am probably just now getting to your question, but hopefully the background makes the rest of this simple. The Header Information array gets split up with the sample rates (the first row in the transposed array), the offsets (the second row), and all the rest of the gains entering the for loops separately. The sample rate sets the dt for the channel, the offset is used to intialize the scaled data array, and the gains are used to multiply the unscaled data. With a linear transfer function, there will only by one gain for each channel. The clever part of this design is that nothing has to be changed to handle non-linear polynomial transfer functions.
I normally just convert everything to volts and then manually scale from there if I want to convert to engineering units. I suspect that if you use the express vi's (or configure the task using Create DAQmx Task in the Data Neighborhood of MAX) to configure a channel for temperature measurement, the required scaling coefficients will be incorporated into the Header Information array automatically when the data is saved and you won't have to do anything manually other than selecting the appropriate task when configuring your acquisition.
Hope this answers your questions.
Chris
Message Edited by C. Minnella on 04-15-2005 02:42 PM
