11-07-2012 06:27 AM - edited 11-07-2012 06:28 AM
Hello all,
I want to convert the excel time stamp to labview time stamp. Can you all please help me how to do this ?
In my application labview time is 05-11-12 14:56:00 and its equivalent excel time representation is 41218.6222222222.
I tried this formula,
Labview time = 24*3600*(Excel time - 1460) but anwer is wrong.
Thanks.
11-07-2012 07:37 AM
11-07-2012 07:40 AM - edited 11-07-2012 07:41 AM
Ok, here's what I found. The conversion is: Time Stamp = 86400*(Excel Time - 1462). But here's the kicker: the timestamp is GMT. You have to add your time zone offset as well. I'm in the Eastern Time Zone, so I had to add 5 hours. I'm not sure what DST will do to this. I'm sure there's ways around it, I just don't have time to look into it more right now.
11-07-2012 10:00 PM
Hi crossrulz,
This logic is not working, Please try the number what i provided in the question.
Thanks.
11-07-2012 11:15 PM - edited 11-07-2012 11:16 PM
Hi all,
What i found is that when representing the time into excel sheet. the difference between time is not constant
#1. 14:51:00 11-05-2012 ------ 41218.61875
#2. 14:52:00 11-05-2012 ------ 41218.6194444444
#3. 14:53:00 11-05-2012 ------ 41218.6201388889
#4. 14:54:00 11-05-2012 ------ 41218.6208333333
#5. 14:55:00 11-05-2012 ------ 41218.6215277778
#6. 14:56:00 11-05-2012 ------ 41218.6222222222
So if the difference between the numbers is not same than we cannot find any common logic for conversion.
Agree friends ?
11-08-2012 06:58 AM - edited 11-08-2012 06:59 AM
There are some slight rounding issues, but the results are fine for me...
NOTE: My date is setup as M/D/Y
11-08-2012 11:40 PM
Its look like that i am committing some mistake. I also tried this but my answer is wrong. Can you please tell me why ?
One more thing how exactly you got this 1462, i think this should be 1460 ?
11-09-2012 06:59 AM
What time zone are you in? Can you attach the actual VI?
I put "1/1/1904 0:0:0" into and cell in Excel and then performed a value() on that cell. The result was 1462.
11-09-2012 09:35 AM - edited 11-09-2012 09:39 AM
Excel has two errors related to its data calculations.
1. Day 0 is Jan 0, 1900. Which of course doesn't exist. Jan 1, 1900 is day 1 in Excel. (There is a 1 day error.)
2. Excel thinks that Feb. 29, 1900 exists as a leap day, while in reality it doesn't. (So there is another 1 day error.)
Day 0 is Jan 1, 1904 GMT in LabVIEW . And since it doesn't have the year 1900, the presence of a leap day in 1900 or the lack thereof doesn't show up in LabVIEW's data calculations.
11-09-2012 10:16 AM
another one.
Time to XL can be downloaded from here https://decibel.ni.com/content/docs/DOC-19689
as well as it's inverse XL to Time
Significantly Excel epoch is dependant on the OS system time zone (Yes, it is insane 0 means midnight on the 0th of January 1900 local time) and there is the famous leapyear bug Microsoft copied fron Lotus)
