Controlling whether charging or discharging process to run
Right now, if the SOC is more than 100, A will be 1. If SOC is less than 50, B will be 1. However, we will have a case where the SOC will be less than 100 and more than 50. When this happen, both A and B will be 0, we will not know if its charging or discharging.
How can we make sure that only either one of the process is suppose to run at anytime?
(2,247 Views)
Accepted by topic author jansencharlie
Hi jansen,
By applying (programming) logic…
You need to store the previous state in a shift register!
(2,230 Views)
