03-03-2015 02:54 PM
I am using agilent 82357B GPIB - USB cable to control thermotron 2800 using lab view 2010
I could find the device in the MAX tool by enabling the NIVIsa tulip.dll option under passports
If i send the Read operation request under VISA test panel ,it always shows up the error "Time out before the operation completed " (Refer attachment)
I am getting the same error even in the VISA Read operation in LAB view .
Is the problem due to the agilent cable incompatibility?
Also ,It would be great if i get the sample vi's that has the GPIB settings and basic commands
(status, setting temperature , etc ) used to control thermotron 2800
03-03-2015 03:03 PM
04-09-2015 07:04 PM
I am a noobie to LABVIEW 2014 and forum. I have an older Thermotron with 2800 controller. I am able to query via MAX. I have installed the TH4800 vi set. Though the 2800 is a simpler controller. Looking for cycle chamber between hot and cold, with Start & Stop functions.
Can you provide guidance and possibly a starting vi?
Appreciate any help.
rickcama
04-09-2015 07:19 PM
04-11-2015 03:01 AM
