Controlling the phase of multiple sine waves
I am currently working on a program to generate multiple sine waves with controllable amplitude, phase and frequency. Through the use of an array within a while loop I can control all of the amplitudes independently, but I have yet to figure out a way to go about controlling independent frequencies efficiently.  I can currently control all of them by setting the refersh rate of the while loop. Is there a method simpler than just hardcoding each control?
Possibly relevant background information:
-Outputting onto a UEIDAQ board
-Controls 32 pins
Thanks for any help
(3,150 Views)
Have you looked at the signal generation VI's they have inputs for phase.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,149 Views)
Mike...
I looked through it, but did not notice something that would allow for simple control of 32 pins.  I may have missed something though.  Could you direct me to a more specific example?
(3,142 Views)
Could you explain a bit more about what you mean by "control 32 pins"?
Mike...
LabVIEW Champion
(3,139 Views)
That was poorly worded and relates specifically to my project, sorry.  By 32 pins I mean that I want to generate 32 sine waves where the amplitude, frequency and phase can be independently controlled.  I can currently independently control the amplitude but have yet to figure out a way to independently control the frequency and phase other than hardcoding everything.
(3,136 Views)
That's where the signal generation VIs come in. They encapsulate the entire process of creating waveforms including setting their amplitude, frequency and phase; and give you controls for setting them independently.
Mike...
LabVIEW Champion
(3,131 Views)
