Hi absias,
this ElapsedTime counter runs even when the case isn't active!
You made the same mistake as in your previous VI: you do the same task in each single case instead of doing it once in your loop!
Put ElapsedTime in the main loop. Use the "Reset" input of that function to start the timer after you switched the case...
