Controlling a NI PXIe-8880 through an external labview system
I've worked with an older NI chasis & NI PXI 8330 controller before, but for a new task I'll be using the NI PXIe-1078 chasis with a NI PXIe-8880 controller and NI PXIe-4140 & NI PXIe-4110 modules.  I'm confused with how to control this system from labview on a laptop.  I've tried connecting via ethernet cable, but it's not being listed in NI MAX.  Should I connect it differently or do I need to fiddle with IP settings?
(3,043 Views)
Accepted by topic author bbentelin
I'm not exactly sure why you would want to do that.  You could use TeamViewer or Remote Desktop or something like that but, normally I just hook up a monitor, keyboard and mouse.  That controller comes with Windows 7 and the chassis is smaller than some desktops.
"Should be" isn't "Is" -Jay
(3,011 Views)
It works wonderfully like that, thanks.
(2,929 Views)
