Control stepper motor
I need to drive a steppermotor (with a stepper driver). For this I'm using a cDAQ-9714 and a NI-9472. The speed of the stepper motor has to follow the profile on the figure below:
How could I do this?
I have tried something but I'm not able to control the number of steps with is (because I use continuous samples).
(2,998 Views)
What DAQ hardware do you have for this?  In a previous thread a couple months back, I didn't think your hardware would support what you're trying to do.  Did I get that wrong?  Or have you upgraded your cDAQ chassis?  One way or the other, is your hardware in fact capable of buffered counter pulse train output?
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(2,977 Views)
I'm using the cDAQ-9714 chassis. I'm able to accelerate but, I can't stop after N-samples.
(2,967 Views)
Have you confirmed that your hardware will generate the buffered frequencies you calculate?  Have you tried Finite Sampling instead of Continuous?
Note: you should write the buffer of freq/duty cycles before calling DAQmx Start.  The query of "Is Task Done?" is mainly for Finite Sampling tasks -- a Continuous task should *never* be done.  The trajectory you made is linear by index, but is by *no* means linear by time.
-Kevin P
(2,954 Views)
