Control and Simulation Software for G
I have read the "Control and Simulation Software for G Reference Manual" and I have a problem following one of the examples. In the example there are a picture (the one attached) of how to connect the blocks, but the name of two blocks to the right is not given. I have tried all blocks I can find in labview that look simulair to these but none of them work. Can anyone help me with this?
(2,314 Views)
Which two blocks are you refering to? The ones on the far right are the diagram side of a graph on the front panel. The object immediately to the left of it is a cluster "bundle" found in the "Cluster" pallette as "Bundle" (vs. bundle by name). The vi's are from the simulation toolkit, if memory serves me as I don't currently have it on any accessible machine.  If this isn't what you are asking try describing what it is we are to look at.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,290 Views)
... and the one all the way to the right is an xy-graph terminal. 🙂
(2,281 Views)
