12-14-2006 01:31 AM
12-14-2006 07:04 AM
Hi Z,
If you use strict type defintion references you can use Call by reference Node. Depending on the connector pane for the subvi which is referenced you just wire your data to the corresponding terminals. I attach an easy example which dynamically opens and writes to an arbitary number of a template.
Hope it helps
12-15-2006 03:29 PM
12-18-2006 02:21 AM
Hi Z,
Now the files should be version 8.0.
Hope it helps,
