01-14-2014 02:17 PM
I've been using a microscope who runs on LabView for some time now and I recently installed a subVI to control a Sutter ROE-200 moving platform. Since then, I've noticed a constant signal in every physical channel (see picture below) by using an oscilloscope. I need to use a PMT detector to measure very low light intensity and the background signal is often higher than the one resulting from a photon. I've measured the frequency of this signal to be 40 KHz.
Is there any way to monitor in real time what is the signal passing through the channels, and to reset or modify it?
Thank you!
01-15-2014 03:37 PM
Hi ndlapointe,
I think software Signal Processing with Filters will help you move forward.
Below is a link to a video that discusses how to use the Filter Express VI.
http://www.ni.com/academic/students/learn-labview/signal-processing/
01-15-2014 03:40 PM
10-17-2015 09:39 AM
what is your subvi? Can you sent to me? I also try to use labview to control ROE 200, but I confront a lot of problem.
10-17-2015 12:11 PM
As a non-engineer who is recording biosignals, I've learned that when dealing with electrical signals, you need to know lots of details to understand what is happening and make sensible suggestions, including:
Noise in electrical circuits is inevitable. What is important is to get the noise level below the level of the signal you expect to record. It would help to know what this is, what frequencies and amplitudes you expect. What sampling rate do you think is important, both from a Control and a Data Acquisition perspective?
10-17-2015 12:23 PM
