11-27-2014 09:22 PM
You need to change that from a constant on the block diagram to a control. Right click on the constant and choose Change to Control from the pop-up menu.
Rounded Numbers 4 and 5 are not connected to anything inside the state machine so only three booleans can be checked. The 1 and 0 constants near the RndNmub VIs are only connected on the first instance. So the others will aways produce zeros. Since you convert back to booleans inside the Initialize state, why not just generate the booleans in the subVIs?
The booleans need to be set before the play button is pressed. Otherwise the value of the array will be read before the user has time to select the buttons. You probably need to re-think the logic and timing involved. The way it is currently written is not very user-friendly.
When a match is found, you need to do something other than Exit to do the scoring and re-try that you said you want.
For a program like this I would sit down with pencil and paper and make a comprehensive document which describes what must happen in each state and what criteria determine the next state. Your description of how the game works is a good starting point. You need much more detail. For example:
- User presses Play
- - Turn off all lights
- - Prompt user to guess
- - Wait for user to enter guess or start time limit for entry
- - Generate random data set
- - Write data to LEDs
- - - Compare data to user guesses
- - - Take action based on accuaracy of guesses.....
Lynn
11-27-2014 09:25 PM
11-27-2014 09:43 PM
11-27-2014 09:59 PM
11-28-2014 10:24 AM
Round number 4 and 5 should be connected to something but i don't why they are not. How can I fix that?
11-28-2014 10:31 AM
First figure out what they should be connected to then wire them up.
I cannot do it for you because I am not sure what you really want to do and I do not have the time to try to figure it out or guess.
Lynn
11-28-2014 10:36 AM
I fixed the random numbers problem. Now how can I fix my code?
11-28-2014 10:42 AM
I just figure out the random numbers part in my new code i posted. Now what?
11-28-2014 01:46 PM
You really need to put together a design for your program. The last piece of code you posted can freeze up under many combinations of button presses forcing an abort to end the program.
It still provides no feedback to the user.
It does not accurately display the results.
With 5 booleans to guess the probability of a correct guess is very low. This will frustrate players unless the rewards for a correct guess are very large.
The image below is a simplified starting point for a design. A comprehensive design may require several of the boxes to be expanded into much more detail. For example Prompt for Guess includes displaying a prompt message (I would not use a dialog box, but that may be one of your requirements), setting the LED Display to blinking, and starting the timer. The flow chart shown does not include any provision for stopping the program. It does not handle errors (what happens if the Arduino gets unplugged while the program is running?). It does not show any of the timing, mostly because I have no idea of what you want the timing to do.
After you get a complete design document, then you begin to implement it in your program.
Lynn
11-28-2014 01:56 PM
thanks this is help. I want to timing to give the users 10-15 seconds to make there guesses. Do you have time where we can work through this piece by piece step by step?
