11-25-2014 01:17 PM
If you hover over the broken wire it will tell you that you are trying to connect an integer to a Boolean. To fix this you should take out the Boolean to integer converter that you are using. Also as was the case before you are still connecting a “False” Boolean to the Digital Write.VI every time. This means that you are always writing False to the Output Value.
I would suggest that after you fix the wiring issues so that you get a non-broken run arrow, try running your code using the Highlight Execution option. This will help you see how your code is running, so that you can see how different aspects are interacting.
11-25-2014 01:59 PM - edited 11-25-2014 02:09 PM
Thanks but my group and I have scrapped that code and working on something similar if you could possibly help us.
11-25-2014 02:10 PM
here are the other files for the new code we are working o
11-25-2014 04:48 PM - edited 11-25-2014 04:49 PM
If you save this as LabVIEW 2011, I'd be happy to help. I've done a lot of work with LabVIEW and Arduino. Otherwise, I cannot look at your VIs due to differing versions.
11-25-2014 04:58 PM
will upload it later tonight how does that sound
11-25-2014 05:05 PM
That's fine, but I won't do anything with it till tomorrow.
11-25-2014 05:11 PM
hey so I hope these work they are 2011 version
11-25-2014 05:11 PM - edited 11-25-2014 05:11 PM
here is the rest of the code
11-25-2014 05:25 PM
I guess I get it. But, you have not attached all your VIs. LabVIEW comes with a tool called Project Explorer. Inside Project Explorer, you can organize all your files (subVIs, main VI, ctrs, etc.). This helps when determining which files are missing. As of now, I believe I am missing Initialize, Close, Digital Write, and Digital Write N Chans. Please organize a project explorer for this project, organize all your files in proper folders, then zip it all up and send. This will be very helpful for you and for me.
11-25-2014 05:30 PM
we are using linx on labview to run the arduino.
Do you understand what kind of game we are trying to play with our code?
