Connecting LabView with the other program
Has somebody ever try to connect LabView with Robocell? If yes, please tell me how I can do this.  Or maybe if not, there is somebody who tries to do this with the other program? Should I add something to my code in Labview to which program the data has to be send?
(2,128 Views)
Hi Kulka!
To connect LabVIEW with any external software, you need a connection point between then, such as a .dll or.NET assembly, ActiveX component, TCP port, file, or anything else that both sides are able to understand. In RoboCell's case, my understanding is that there is no such interface created (it is a GUI-only application). This being the case, the only way of communication I can think of is through files.
Kind regards:
Andrew Valko
National Instruments Hungary
(2,073 Views)
