12-28-2013 05:59 AM
Hi every one
I am trying to connect solidworks assembly with Labview using softmotion modules
I followed multi tutorial to do that even I tried softmotion user guide but my project still not working
even I tried to open original example in labview (Located in :C:\Program Files (x86)\National Instruments\LabVIEW 2011\examples\motion) but the results were the same
the project in labview deployed successfully but when I started VI the motion study in solidworks not started.
I followed steps in the link Troubleshooting SoftMotion for SolidWorks but the results were the same
I am using Labview 2011 and softmotion 2011 , solidworks 2013 sp0 premium
and windows 7 64bit
I don't know if I
- should install additional tools
or not working on windows 7 64 bit
or something else ???????
Any one can help me !!!!!!
Thank you all
01-03-2014 03:07 AM
Hi abddabbour,
Firstly, welcome to NI forums.
Secondly, can you please be more specific what does it mean it doesn't work? Do you get any explicit errors when you are following the steps in the tutorial?
Can you post the files you are using?
What hardware are you using in your system?
IR
01-15-2014 03:51 PM
Thank you very much for your replay
and I am sorry for late respond .........
First I mean by "doesn't work" that like every tutorial I found about this when deploy your project in labview the simulation in solidworks should be start
but that doesn't happen and no error appears.
I tried example in labview which are exist in "\National Instruments\LabVIEW 2011\examples\motion\SolidWorks"
I am using labview 2011 and solidworks 2013 sp3 on windows7 x64
Note :
Recently I tried same steps on the same example but using labview 2011 and solidworks 2012 on windows x32
and it work perfectly ,the only missing step was I must press "start simulation" from labview after deploying project,
but even after that motion on solidworks still not working when I use labview 2011 and solidworks 2013 sp3 on windows7 x64?????????
Thank you very much again
