Configuration file corrupted
After NI update have a message "Configuration file corrupted, need reinstall software". Is this the end?
(2,130 Views)
Hey trafficline,
My suggestion would be to either delete or rename your .ini file. To do  this make sure that all LabVIEW processes are not running, if they are close them. Then delete or rename your ini file. After that run LabVIEW once again. When LabVIEW detects that there is no ini file where it expects it to be, then it will create a new one. Hopefully that helps.
Paolo F.
(2,069 Views)
