05-15-2012 06:10 AM
hello,
i have a problem with labview.
I communicate with a serial port and I have labview program in 2computers(the same program) and the program works on a computer and not in another.
I think the problem is in the attached images, the image is the one I Labview2 runs OK, but the image Labview1 fails.
Why does the same program reacts differently?
thanks
05-15-2012 06:19 AM
I do not see any problem on your VI.
You have some difference on your probe because the font on your two computer is not the same.
Yoann
05-15-2012 06:40 AM
the font of the letter?
i think that the problem is in the conversion of first two characters to string or in the labview configuration, because is the same program in the 2 computers!
For example, i have a problem two months ago, with the configuracion configuration point decimal in labview.
do you know if exist in labview any option to return to default settings?
05-16-2012 06:23 AM
Yes default font of your application. For example:
String indicator => shows the string in \ Code
String1 indicator => shows the string in my default application font
String2 indicator => shows the string in MS Sans Serif
The probe shows the result in the same format of yoru application font
=> it does not shows the same thing. Use a string indicator to test your function and set the font to a default one
Yoann
