08-23-2013 09:06 AM
When changing a for loop terminal from indexing to conditional, the for loop and any containing structures expand even when they are not set to Auto Grow.
When selecting multiple conditional tunnels and and choosing Vertical Compress from the Distribute Objects menu, the tunnels are compressed as if they don't have condititonal terminals.
Are either of these bugs known or corrected in LabVIEW 2013? I could not find anything on NI.com when searching for "conditional tunnel autogrow".
Matt
08-23-2013 12:14 PM
Matt,
A Very nice example of unexpected behaviour!
Steps to reproduce:
Sounds like a small oversight-- but a deadly potential for breaking code that is impossible to find without a divining rod!
BOLO (Be on the lookout) for this type of bug.
08-26-2013 10:59 AM
Thanks for reporting this!
I can easily reproduce the autogrow behavior in 2012. I don't see an existing CAR for this, so I will file one.
I am not seeing the behavior you report when distributing the items or Control+Shift+J (send to back). Can you please supply screenshots illustrating this?
08-26-2013 11:23 AM
I have filed CAR 423949 against the VI Analyzer's Hidden Tunnels test, as it currently does not take the '?' part of a conditional tunnel into account.
Joey, I suggest you file two CARs...one for the growing behavior, and another for the fact that Vertical Compress does not respect the '?' part of a conditional tunnel when compressing objects.
08-26-2013 12:29 PM
Hi Matt, Jeff, and Darren,
I have filed CAR 423935 for the Autogrow issue, "Creating conditional terminal on For Loop causes loop to grow even if Autogrow is disabled", and CAR 423937 for the Vertical Compress issue "Vertical Compress causes For Loop conditional terminals to stack so that tunnel is obscured".
Thanks for pointing these out!
08-27-2013 09:40 AM
Thank you guys!
These are not the most egregious bugs... but as a developer, I hate it when a user asks me if I fixed xyz bug but she never told me about the bug!
So I make an effort to let you know what I notice, and I appreciate you noticing what I let you know. 🙂
