07-07-2016 06:04 AM
Hello!
I would like to create VI to put together a step diagram for operating 6 valves.
On this front panel I imagined a table, where the steps are positioned under each other like rows in a table.
Every step has to be timed and the valve positions has to be set. I need at least 30 steps, so it would be nice to create a table, with every line similar to this:
I dont really know, what is the best oprion in this case. Copy pasting 30 times seems like a very amateur solution.
Does anybody has some ideas?
Thank you in advance!
Adam
Solved! Go to Solution.
07-07-2016 06:13 AM
07-07-2016 06:25 AM
Thank you!
Works like a charm.
