11-10-2004 10:54 AM
11-10-2004 11:16 AM
12-28-2006 03:03 PM
12-29-2006 12:49 AM
12-29-2006 01:35 AM - edited 12-29-2006 01:35 AM
Message Edited by altenbach on 12-28-2006 11:37 PM
12-29-2006 04:21 AM
Here's another version, probably more efficient on larger arrays than Alten's, because even though it has to allocate an extra n*2 bytes array (the conversion to 0,1 which produces an I16 array), it avoids having to allocate the n*4 bytes, avoids running over the entire array (fewer iterations) and avoids having to do the cutting.
I didn't bench them, though.
12-29-2006 11:58 AM - edited 10-25-2014 12:13 PM
I suspect that the result is quite input dependent and it would be worth fine-tuning on typical data. Last night I actually made two more quick version as a little exercise (see picture).
(A) is probably very efficient for very large input arrays with very few differences.
(B) is probably good for very large input arrays that are mostly different.
(Notice that my example uses integers. As we all know, comparing floating point with "=" or "!=" can lead to somewhat unexpected result, depending on where the data has been. :))
tst, while "search array" is very efficient, it still needs to "run over the entire array" one way or the other, just internally to its function in this case. 😉
JQ, your code is incorrect because it can lose output data in the worst case scenario. Since there is no data dependency between where you initialize the output array with an empty array (lower left of code) and where you write to a local variable of it (inside the loop), it could happen that the array is cleared after some values have already been written to it. Code does not necessarily execute left to right and your code does not define what should happen first. Such race conditions are an inherent side effect of careless use of local variables. Whenever local variables are used, the code needs to be carefully reviewed fo such things.
Message Edited by altenbach on 12-29-2006 10:00 AM
12-30-2006 10:11 AM
I would definitely agree to that - all these are highly dependant on the typical input data and on things like potential compiler optimizations and such, and where such efficiency is needed, some real testing needs to be done. I agree that your first implementation is probably more efficient and I know better than to try to fight you on optimization issues unless I have the time to do all the necessary testing . In any case, I doubt the original poster will need all this.
Valid point. It was, of course, just a very quick example.
Well, you know what I meant.
tst, while "search array" is very efficient, it still needs to "run over the entire array" one way or the other, just internally to its function in this case. ;)
12-30-2006 12:29 PM - edited 12-30-2006 12:29 PM
Oh yes, the problem is certainly solved!
I agree with everything you said. In 99% of all cases the simplest code is appropriate because performance is not an issue. Nobody cares if it takes 0.1 or 10 microseconds. 😉 If performance is an issue, I never trust my instincts until I see actual benchmarks.
@tst wrote:
... In any case, I doubt the original poster will need all this...
Still, there are many readers with varying LabVIEW experiences that come here for entertainmentideas, and a spirited, somewhat more global discussion can break the monotony of (problem->solution ... problem-->solution ... bug--> workaround ... problem-> solution....). A few illustrated side-trips here and there can stimulate the thought process, give ideas how to do things differently, and point out how the diffferences potentially affect memory use vs. speed vs. code readability, etc.
Have you noticed that a large percentage of code posted here recently uses insert into array instead of build array to append a single element to an existing array? For me this complicates code readability because it is not universally obvious why "insert into array" would even act like that when the index is not wired (without looking at the help, some might guess it gets inserted at the beginning). With build array, there are no unwired inputs and it is immediately obvious that the element is added at the end of the array, just by looking at the icon.
Hopefully we got some people interested enough to duplicate our various versions, run some benchmarks, and try to come up with competing code that's even better. 🙂
LabVIEW is fun!
Message Edited by altenbach on 12-30-2006 10:35 AM
12-30-2006 04:21 PM
@altenbach wrote:
...it is not universally obvious why "insert into array" would even act like that when the index is not wired (without looking at the help, some might guess it gets inserted at the beginning).
Here's a nice one for you - in at least one version of the PDA module, the Insert into Array primitive did insert the element at the beginning of the array, but only after your code was converted to C and run on the PDA. That did for some fun debugging (and don't ask me why I used it instead of Build Array. I really don't remember ).
Hopefully we got some people interested enough to duplicate our various versions, run some benchmarks, and try to come up with competing code that's even better. :)
Yeah, right.
