06-04-2014 03:55 AM
I need to collect around 10 cycles from a sinus signal with Labview. I'm using the DSO Agilent 6052A and a VI witch allows me to collect only 2-4 cycles.
I tryied to find how to change the autoscale parameters, in the DS0 preferences and in the VI but I didn't succed.
Do you know if i have to modify somethings in the oscilloscope parameters, or in the labview program ?
Thanks.
06-04-2014 06:38 AM
Sounds like you just need to change your timebase. Most scopes have 10 horizontal divisions (verify this on your scope and adjust as needed). So since you want 10 cycles on the screen, you need your timebase to be at least 1 cycle/division. If you have the drivers, there should be a VI to set the horizontal scale.
