Communication issues with COM port
Thanks!  This tells me it is a non-SCPI compliant device, so the *OPC? command will not work.  This also tells me that it may not even respond to a command to read the STB.  The other thing that tells me this, of course, is that you are getting a timeout when trying to do so.
There seems to be some query commands included with the command set.  See if you can implement those instead.
Bill
CLD
(Mid-Level minion.)
Message 21 of 27
(789 Views)
STB and OPC are GPIB functions. You have to use the DON? query per the manual.
Message 22 of 27
(774 Views)
You can send them via VISA?  I thought they could only be reached through the GPIB palette?
I guess I was just being dumb about things.
Bill
CLD
(Mid-Level minion.)
Message 23 of 27
(770 Views)
No, VISA can read them. The main point I wanted to make is that the functions are defined by IEEE-488.
Message 24 of 27
(766 Views)
And I was being particularly dumb because I remember you saying that a couple of times and I keep forgetting!
Bill
CLD
(Mid-Level minion.)
Message 25 of 27
(758 Views)
Thanks for all your comments!
I can indeed use the MONO-?DONE command to verify if the device is done or not. But, if it is busy, it cannot display the 1/0 value in the buffer, because it is busy. Is this true? Or am I completely misunderstanding something?
I now temporarily solved the issue by estimating the waiting time based on the input parameters - it's a bit cumbersome though, and certainly not the most time-efficient solution.
Message 26 of 27
(730 Views)
It may well be a limitation of the instrument. I would check with the vendor. I don't think it is a problem with LabVIEW.
Message 27 of 27
(723 Views)
