10-08-2009 01:16 PM
Whenever I run a certain FPGA VI I get an error saying:
An error was detected in the communication between the host computer and the FPGA target
If you are using any external clocks, make sure they are connected and within the supported specifications. Also, verify that the rate of any external clocks match the specified clock rates. If you are generating your clocks internally, please contact National Instruments Technical Support.
This VI has run fine in the past and I am not sure what has caused this change. I can run other FPGA VI's in my LabVIEW project without any problem. The VI does not make use of any external clocks as far as I know, though I am a little unclear by what would be considered an external clock. This particular VI monitors an Analog Input and controls two motors with PID control through two Analog Outputs.
I am not sure what other information is required to further describe this problem, so please let me know if I have left anything out. I am running LabVIEW 8.5 on Windows XP SP3.
10-09-2009 02:24 PM
Hi jbailey,
What version of NI-RIO are you using? Does copying the code to a new VI cause the same issue?
10-12-2009 10:17 AM
10-12-2009 12:08 PM
10-12-2009 12:53 PM
