05-30-2007 12:46 AM
05-30-2007 04:27 AM - edited 05-30-2007 04:27 AM
Message Edited by unclebump on 05-30-2007 04:27 AM
05-30-2007 08:30 AM
StevenK wrote:Hi, All LV Experts.I have 1 project which require using LV 8.2 to communicate with Omron PLC model CJ1M-CPU11,... how to develop such project without using OPC Server. ...
You may want to take a look at a download available at MrPLC.com that allows the CJ1M to serve as a modbus slave via the CPU's serial port. I think it's also available somewhere from Omron. Haven't used it myself.
<snip>
The Slave Interface allows the use of CS1G/H and CJ1G/H/M to be used like a slave device of MODBUS network. The PLC responds to the commands of a Master MODBUS device connected to the CPU RS232 port of an OMRON CS1/CJ1 PLC. The Slave Interface responds to commands 03H (reading from data memory) and 10H (writing to data memory).
<snip>
07-12-2012 02:23 AM
I think you can see this artical:
http://www.smartlabx.com/blog/labview/73-how-to-communication-between-omron-plc-and-labview.html
10-25-2013 08:43 AM - edited 10-25-2013 08:43 AM
01-23-2015 04:22 PM
It looks like that article has moved again. Does anyone know where it might be now?
Thanks.
