10-17-2013 04:13 AM
Exactly that is my point. Do you have any link regarding that.
10-17-2013 04:20 AM
10-17-2013 04:31 AM
May be my words were not correct.
Thanks for your concern.
10-17-2013 05:12 AM
Ranjeet_Singh ha scritto:
Hello all,
I am programming PIC IC using command line and passing arguments. In that If I pass the complete syntax then it does all the process and ends with programming. Now I do have a requirement in which I need to program multiple ICs.
My command line syntax is
cmd /c ICD3CMD /P18F26K22 /E /M /F"D:A.hex" -- This will do all the job from starting to end.
Here programming is done using argument M/F"D:A.hex"
When I need to program multiple ICs then I only need to pass M/F"D:A.hex" as arguments to system exec. How to achevie this?
It's very likely that M/F"D:A.hex" as an argument of a command line program is not valid.
Try with /M /F"D:A.hex".
The full command line would be
cmd /c ICD3CMD /M /F"D:A.hex"
I'm suggesting this without knowing anything about the programming application.
10-17-2013 05:21 AM
pincpanther..I just want to tell about argument....
10-17-2013 05:28 AM
I don't understand. I was talking about the argument too.
So what's the full command line you are trying?
10-17-2013 06:07 AM
See my fisrst post. That is complete syntax.
/M/F"A.hex" is the arguments that need to be passed each time.
10-17-2013 06:12 AM
Hi Ranjeet,
you cannot call SystemExec with just arguments. You have to give a full command with it's argument!
When you have to submit new arguments again and again, then what's the problem in calling the (full) command repeatedly?
10-17-2013 05:14 PM
Sounds like this may be something similar to what mySQL does when you start a command line session by running mysql.exe....The command prompt changes to
mysql>
until you type 'exit'....which returns you back to standard prompt. Sending another command to SystemExec using only parameters is not going to use the existing session.
10-17-2013 11:04 PM
@GerdW wrote:
Hi Ranjeet,
This take 25 sec each time. When I will pass the only arguments which needs to be passed each time then it will take 2-4 sec.. Becasue if I pass all the argument each time it does all the thing from initialization till programming which lasts for 25 sec. Only programming takes 2-4 sec.
