07-05-2015 06:28 PM
Excuse me, Can you explain me, Why my Cronometer doesn't work while I'm doing it? It works before to do this thing about Event Case, but now It doesn't work 😕 But Comobox part work really well 😄
07-05-2015 06:51 PM
What is cronometer?
07-05-2015 06:53 PM
Elapsed Time, this part "Minutos muestreados" doesn't work 😕 and I don't know why.
07-05-2015 06:58 PM
You have an event structure. It only executes when you have an event, in this case the value change on the one button.
If you need to keep a running track of elapsed time, create a second timeout event. That will execute periodically whenever no other events occur.
07-05-2015 07:19 PM
Yes, I got it, but I need to have all the program inside Event case or not? I don't unerstand what I have to put inside Event case in my program.
07-05-2015 07:30 PM
Because you don't want to have the button be true for multiple loop iterations (like it could have been in your original code) and have it register 2 or 3 times when you only pressed once.
You've now seen how you can do it. Figure out how to make it work better for you. You situation sounded to me (and to others) that it needed an event structure. There are other ways to do things, and maybe one of those don't need an event structure. Try to figure out other methods for yourself.
07-05-2015 07:36 PM
I'll try it 😄 Thanks for help 🙂
07-05-2015 08:40 PM
Hi 🙂 excuse me, Can you teach me how to activate this Elapsed Time with a pulse? Not keeping push the button how I'm doing it. Please 🙂
07-05-2015 08:42 PM
Don't use Switch until released.
07-05-2015 08:46 PM - edited 07-05-2015 08:59 PM
Yes, but I want to reset it with a switch, Can I do it?
I want to start the Elapsed time with the switch.
