02-23-2015 02:35 PM
I am trying to combine two different simulated signals into one. When I use the
Merge Signals function, I do not appear to be getting the results I am
desiring. On the Waveform Graph it is appearing as two separate signals. How do
I combine signals to merge into one? What am I misunderstanding about the Merge Signals function?
Note: I am trying to simulate an output signal that has a dither frequency riding on top of it.
02-23-2015 02:38 PM
02-23-2015 02:48 PM
had wondered if a basic function would be simpler, but hadn't tried. Thanks for the thought.
