Combine elements of a 2D array by Row
Hi all,
I am pulling in a column of Dates and a column of Times from a text file, creating a 2D array of this data, and then I am stuck trying to merge the two columns together.
For example, I need to take the Date and Time data from Row 0 of the 2D array are combine them into Index 0 of a 1D array. Then I need to convert this "time stamp" into seconds. Attached is an example.
Any help would be much appreciated
Erik
(2,413 Views)
Accepted by topic author EMunson
Do you need an array of strings? What character(s) will separate the data from the time?
Conversion to seconds using the LabVIEW epoch of 12:00 AM, January 1, 1904 is fairly straighforward althoug properly accounting for Daylight Savings Time and leap seconds can be tricky. Conversion to any other epoch requires more effort.
Lynn
(2,391 Views)
No that looks fantastic in the end I just need the seconds array which you included.  Thank you so much!
(2,379 Views)
